Hello.
I have this small issue.
Will a 12 mm H7 hole fit with a 12 mm h7 shaft? To a degree where it is possible to mount by hand?
Most places I see tolerances specified like H7/h6.
Thank you beforehand :)
Printable View
Hello.
I assume you are referring ISO 286-1 & 2?
H7 tolerance for hole is +0 / - 0,018 mm
h7 tolerance for shaft is +0,018 / -0 mm
Mount by hand? Probably not...
What is the application?
That's what I am reffering to.
Yeah, I thought so.
It is the shaft of a motor that has to fit into a pulley, unfortunately the tolerances are H7 and h7.
Edit:
I am also not interested in backlash of any kind, since I need to be able to control the setup with a precision of +/- 0,2 mm
FYI,
See ---> [URL="http://www.engineersedge.com/manufacturing/preferred_mechanical_tolerances_metric_iso_286_13166.htm"]ISO Preferred Mechanical Tolerances[/URL]
[URL="http://www.engineersedge.com/calculators/mechanical-tolerances/table_hole_tolerances.htm"]ISO Table of Metric Hole Tolerances[/URL]
[URL="http://www.engineersedge.com/calculators/mechanical-tolerances/table_shaft_tolerances.htm"]ISO Table of Metric Shaft Tolerances[/URL]
