1 Attachment(s)
Ventilation System for Diesel Generator Set
[SIZE=3][FONT=tahoma]Hi all,
I was assigned to design a standby diesel generator set for a shopping mall in Malaysia which holds a Power Rating of 1500kVA. The genset room is located at Basement 1, thus I am designing for a remote radiator system.
Referring to the attached catalog, the amount of heat rejected to the coolant is 511kW - and I have designed the required capacity fan for the radiator.
The question is, do I still have to provide ventilation system for the Genset Room itself since it was mentioned that there will be heat rejected from the engine and alternator to the room - about 181.9kW?
I would really appreciate some help here.
Thank you.
Regards,
[I]Hafiz
Mech. Engr[/I][/FONT][/SIZE]
