Binding Rope/Strap selection
Respected forum members
I have a question regarding the selection of rope/suitable binding for attaching dead weights around the wind turbine generator. I have to attach two 20 kg dead weight blocks(rectangular steel bars), one above and one below the generator (diameter of generator: 350 mm). Since the turbine is already installed, the only possible way is to use some rope or straps to tie this dead weights steel bars around the generator.
I am not so experienced with the suitable rope/ straps that can be used in this case, would you mind giving me some suggestions regarding which rope/ suitable rubber strip traps that can be used.
Thanks in advance
