Dear fellow engineers, does sombody know if there is such a thing as lead-free soft alloy (low hardness, probably HV ander 100) accessible of-the-shelf in form of sheets or patches with thickness about 0.010" (0.25 mm)?
Printable View
1100 Aluminum shim stock...
Fully annealed Copper sheet.
Thank you. Will try to find. I guess I need something softer. Something like tin sheet, or tin-silver alloy. I need to squeeze it with screws between two flat aluminum surfaces to make joint water tight. However, it still has to be conductive.
[QUOTE=Vladimir;1540]I need to squeeze it with screws between two flat aluminum surfaces to make joint water tight. However, it still has to be conductive.[/QUOTE]
What about this...
Er, um, make that something other than copper washer as electrolysis will eat the aluminum it away. I missed the "aluminum" bit. :)
There are some polymers now that are conductive. They are even flexible and make decent gaskets.... Try a custom compounder. They even have molding presses that can run off samples and maybe you could get one of the samples and modify for your application....
Thanks a lot to everyone. I accidently found a solution. GHood luck to all of you.
