Precedence constraints/relationships for manufacturing processes (academic)
Hi guys, I am hoping you could refer me to some references.
I am doing research on manufacturing process planning (not much background in manufacturing).
In machining, there are a bunch of heuristics which specify the sequence in which the different features are to be machined. E.g if a surface is used as a datum, then this surface is machined first ( so that all the remaining features will be based on that surface)
However I am looking for a set of general rules that can be applied outside of machining, which considers all the different types of manufacturing operations, which include joining processes, material additive processes e.g cladding, material property enhancement etc... I know that this normally comes with experience and is very circumstantial...
what I am looking for is some reference where all these little and important heuristics can be found?
What I have found so far are only general guidelines.
Whereas for machining you have such a well defined, extensive set of rules.
Thanks.
