Heat loss through large air ducting
Hello everyone. I'm a student engineer on a work term and I've been running some very rough calculations on the exhaust air of a client of ours. I'm looking for the heat loss that's being pumped to the exterior of the facility through an exit duct. What I have for information is:
-flow rate: 40 000 CFM
-exit air: 20 degrees Celsius, standard indoor humidity humidity
-inlet air: -20, -10, 0, and 10 degrees Celsius, standard indoor humidity (the different temperatures reflect seasonal temperature changes)
-The degree days for our example location are 5132 (value taken from Environment Canada's website)
-Exit and inlet will have the same cross sectional area of 80 square feet
I have applied the first law of thermodynamics to determine what the heat loss is in btus/hour but I don't know if the number is correct.
I'm assuming that the degree days were in the Celsius scale and so the average daily temperature for a year would be 5132/365 = 14.1 degrees Celsius = 57.38 degrees Fahrenheit.
Here is what my original equation looks like:
Heat loss = (40 000 CFM) x (1.08 (BTU*min)/(degree Fahrenheit*ft^3*hour)) x (68 degree F - 57.38 degree F) = 458 784 BTU/hour
My question is whether or not my chain of reasoning makes sense here? Any suggestions would be really appreciated!! Thanks!
