1 Attachment(s)
Need help with a Planetary Gear Arrangement
Hi all,
I need help with a Gear Train described below. A rough sketch is attached.
I have a Round Plate above which there is a 88 Tooth Gear (Gear A). Both have their own drive and the ratio is 1:4. For every 1 turn of the plate, the Gear A rotates 4 times. They both rotate in the same clockwise direction.
On the plate is fixed a Gear B which meshes with the 88 Tooth Gear A.
I want it such that for every 1 rotation of the Plate, the Gear B rotates 18 times.
I am unable to figure out the no. of Teeth for Gear B, and would be grateful for any help with the formula/calculation.
If required, I can change the ratio between the Plate and the Gear A and/or the No. of Teeth on Gear A.
[IMG]http://www.engineersedge.com/engineering-forum/attachment.php?attachmentid=1943&stc=1[/IMG]
