2 Attachment(s)
Aluminum Utility Trailer Frame Design
I am a non-engineer wanting to get some engineering feedback on a trailer design that I would like to build. I have attached drawings of the intended design. All main frame perimeter rails, tongue, and tongue bracing to be 2X4X1/4 rectangular aluminum 6061 tubing, and the cross bracing to be 2X3X1/8 tubing. For the 5/4x6 wood decking, I would use 2X2X1/8 tubing for the intermediate supports, and 1x2X1/8 tubing for the perimeter ledger supports. All connections to be welded. I am planning on a 3500 LB torsion or spring axle to be mounted to the underside of the side rails. I am not sure of any other dynamic load concerns regarding actual road travel that need to be considered.
Thanks for any advice, and let me know if there is any other pertinent info that is needed.
