guidance needed on support plate for ambulance stretcher mounting
hi, to all
newbie to this site.
i would like to ask for help regarding regarding the dimensions for mounting a stretcher support plate,in an ambulance.
were mounting a ferno power load stretcher that has a interrior mounting install plate. we have to place a supporting bracket under the chassis to withstand the following spec taken from strykers install manual.
"Each bolt and support structure must be able to withstand 2,750 lbf (12,230 N) in upward tension and 600 lbf(2,669 N) in shear in all horizontal directions."
found in this install manual REMOVED
so i guess we can use steel or aluminom as a plate,which we would tap, but what would those dimensions need to be?
thanks so much
david
