no play peg in hole that locks but can be removed and replaced easily
Hi, This is my first post on the forum. Hopefully someone will be able to help me out.
The problem I have is getting a no-play fit between a tube and a hole. The part in question is around 33mm OD (and min 20mm ID), around 800mm long. The requirement is for this part to fit into a hole and lock into place providing virtually no play in all directions and lock in place BUT is required to be easily inserted and removed (with some kind of catch?). With a standard peg in hole fit with plastic parts and moulding tolerances even low CPK values will mean that a worst case fit will translate to a large amount of play at the end of the 800mm tube.
Ideas I have been experimenting with so far are non-locking taper fits (7 degrees or more). This works well however im struggling to work out how to keep the tube held down. The variation in tube/taper size diametrically means that the parts can vary vertically by a few mm and a catch would be required to work over this distance. The taper works well as long as the parts are held tightly face/face against each other. Any lift of the tube will result in the parts breaking away from each other when load is applied.
This seems like quite a universal engineering problem however im still finding it difficult to find an application where it may be used already. Any ideas would be much appreciated.
Just to add, the inside of the tube on both male and female parts (min 20mm) has air-flow and needs to be free of any restrictions.
Kind regards
