1 Attachment(s)
Question on defining run-out between multiple holes of identical diameter in pairs
Hi all,
I have jut completed the Level 1 course on Geometric tolerancing to BS8888 and ISO standards but I am finding it quite difficult to apply it to my own drawings. Any help on tis problem would be appreciated.
The part I need to tolerance (see attached) has 4 diam6mm holes and 8 diam5 mm holes. I would like to:
1) have the four diam6mm holes circular and concentric to each other, enough to fit a long shaft through them with an H7/h6 location fit.
2) have the other height holes toleranced by group of two so that:
- I can fit a small shaft through each pair with an H7/h6 location fit.
- the axis defined by the pair of holes is parallel to the axis defined by the 4 diam6mm holes
- each pair of holes is toleranced independently to the other, I do not want to over constraint he part by making all holes aligned.
I have tried to use a run-out tolerance to control the circularity and concentricity of the holes at the same time but I don't know how to make it clear that it should apply to each pair without repeating it four times. Also, which one is the correct way to define datum B: B1 or B2? and would B1 apply to all four holes because of the "4x"?
Many thanks for your help,
Alizee
