Where in Y14.5M is Third-Angle Projection identified as the default?
Where in Y14.5M is Third-Angle Projection identified as the default? I've found MANY assertions online and in forums that third angle is the default in ansi / asme Y14.5M-XXXX (specifically looking at the 1994 version). However, I cannot find that default in the TEXT of the standard. Is the 3rd angle default in the standard, or some other reference standard? Most of our customers will specify the projection on their drawings... but some will not, but will instead have "interpret per ansi Y14.5M-1994" or similar. We just want to be certain that the standard clearly calls out the projection one way or the other. Thanks!!
