1 Attachment(s)
Help!! Pressure loss of air poppets
I have need to figure out how much pressure is lost in a system when each air poppet is cracked. Can I make four poppets crack open at the same time using the same air circuit?
I am applying 80 PSI to a .3437 dia drilled line 5 inches long. Each air poppet ties into this line (4 times evenly spaced). I need to then push a shoulder bolt (.3125 dia head). The shoulder bolt has a spring that needs to overcome 6 lbs of force from the air pressure to crack the air poppet .015. I have all this displayed in a pdf attached to this post.
Any help is much appreciated.
Thank you
