Formula to cool water with air
I need to determine how much Air is needed to cool a copper tube. The air will be blowing on the outside surface of the tube as there will be water running through the tube.
The starting temperature of the water will be 70°C and the goal end temperature is 35°C...all done in less than 2 minutes. I already know that it will take ~250 W to do this; however, how would I determine the amount of air needed? Am I looking for the velocity of the air to cool it? If so, what equation should I use to solve for this?
I won't be able to have room temperature water available to cool the solution, neither will I be able to use ice. This needs to be repeated on command, so I'll need a fan that will kick on to cool the piping as the 70°C starts flowing through.
As you can see I'm quite rusty on my heat transfer and thermodynamics. It doesn't help that I can't find my textbook from when I was in school either!!
