What is the difference between an EN grade and a EN number?
Printable View
What is that code or image you're attaching to our forum?
Respond and we'll address your question.
It is an image showing an EN grade and an EN number.
The file attachment was posted in binary form and could not be viewed. I thought initially it was a hack attempt however I am unable to demonstrate that is was.
Please repost the image as a different format, jpeg etc..
[ATTACH]2676[/ATTACH]
Grade is a subpart specification in a standard and the number should have been represented as a EN number. Thus, X5CrNi18-10 defines the material grade in terms of the chemical composition and 1.4301 is the EN designation for the material.
X5CrNi18-10 (EN 1.4301) is a Stainless Steel defined under many EN and other standards Other countries standards embrace this material and re-publish under their own standards, e.g. BS (British Standard), DIN, etc.
For example, AISI 304 standard is roughly the same materials as X5CrNi18-10 (EN 1.4301).
Thanks for the answer.
Does it matter if i use [COLOR=#333333]X5CrNi18-10 or EN 1.4301? Will it mean the same thing?[/COLOR]
I would use both, e.g.
Thank you!
