What components and information will I need to make a 12v ac generator power a 6v dc motor?
Printable View
AC to 6 Vdc converter...
if you want to build it by yourself , then you need to build this scheme :
[ATTACH=CONFIG]2140[/ATTACH]
As you can see 4 diodes ,1 resistor and 1 capacitor are the components to build AC-DC converter
and then to filter out only 6V from 12V generator i would use zener diode VOLTAGE REGULATOR
[url]https://www.youtube.com/watch?v=8G6rGZDiEBM[/url]
(be sure to use 6V zener diode not some lower volt ones)
