Bidirectional bearing wear
My conceptualized setup:
I have a radial ball bearing inner race mounted to a shaft that spins at constant rate. The housing of the bearing is mounted to the inner diameter of a cylinder that spins in the same direction as the shaft at half the speed of the shaft. There is also an axial load on the bearing.
My question:
Will the bearing wear out quickly and seize? Is this configuration feasible?
[QUOTE=Cragyon;17058]If the bearing is sized properly, to the loads, thermal environment, RPM, etc. ... no, the bearing will not "wear out quickly".[/QUOTE]
The balls in the bearing will roll in one direction when torque from the spinning shaft is applied. Torque applied to the cylinder in the same direction as the shaft with the bearing housing mounted on the inside diameter of the cylinder will apply a force on the balls tending to move them in the opposite direction. This, to me, implies that the balls will slide instead of roll.
Will there be an increase in friction inside the ball bearing?
