1 Attachment(s)
Portable ski grinder - Angle control
I'm currently working on a school project in which I have to design a portable ski sharpening device. The product will consist of three main parts : The base part which will be in contact with the ski, a sliding part with a spring which will apply a constant pressure on the edge of the ski and a top part which will hold the motor and grinding wheel (See drawing).
[IMG]http://www.engineersedge.com/engineering-forum/attachment.php?attachmentid=1331&stc=1[/IMG]
The top part must also be adjustable so it can grind a different angles (from 90 et 85 degrees with a 0.1 increment) and I can't figure out a simple way to do so. Does anyone have a mechanism idea or any standard part that could adjust the angle by increment?
Thank you,
Fred
