Ring gear with both internal and external teeth
In a hybrid transmission, there is an epicyclic gearbox. An input to the sun gear is given from the internal combustion engine, and another input to the ring gear is given from a DC motor. The output is taken from the planetary carrier. I have confusions as to how the input from the motor is to be given through the ring gear.
Is it possible to have a ring gear with both internal and external teeth, with the internal teeth meshing with the planetary gears, and the external teeth meshing with a reduction gear from the motor input?
If that is not possible, what could be an alternative way of giving the motor input through the ring gear?
