The attached file shows a position callout for a hole that has an axis that is parallel to the primary datum. I understand that if the primary datum is perpendicular to the axis of the hole, then perpendicularity is controlled. With the primary datum parallel to the hole axis, is parallelism controlled? Is this position callout even valid? If not, what part of ANSI Y14.5 is violated?
Thanks
