Automated door two actions...
Hello, I need to create automation for a two action door. Looking for some expert help on simplest way to achieve this. The door needs to swing up 90 degrees verticle, from verticle to horizontal. Then it retracts into cabinet. I realize you will likely need to know dimensions, travels length, and weight of door. Any other info you would need to help suggest how to go about this. I had thought of a linear actuator to lift, then I could do a second for the retraction, just wasnt sure if there is a simpler way with one device instead of multiple. I want to build this to open and close via outlet command from an Amazon Alexa device.
