Hi
I want to test some receiprocating parameters of an Assy A (mass=10 Kg) by using 5 cylinder engine. II will be rotating crankshaft by using motor, not by combustion. Assy A will be connecting to middle cylinder (cylinder 3) and reciprocating while crank will be moving at abt 2000 rpm. Can any body suggest some way to find what weight should I attach to cylinders 1 and 5 (outer cylinders) in order to balance crank. Firing Order is 1 2 4 5 3 ?
Regards
