Determining noise levels?
I love working outside my area of expertise. I have you guys to bother when I come across something I am with which I am unfamiliar...
Do any of you have experience in determining noise levels for equipment? Specifically, an enclosure I am working on requires approximately 2700 CFM of airflow for cooling purposes. Our customer has asked that we achieve this airflow through the use of multiple fans. The reason for the multiple fans is in the event of a fan failure, airflow will continue, albeit at a reduced rate. The current configuration utilizes 12 fans.
Now comes the challenge... I have been asked to provide a cooling fan arrangement that meets GR-63-CORE requirements with regards to noise levels. I have researched the document and found the standards by which the fan arrangement will be tested, but I am not sure as to how to determine the overall noise level of a collection of fans. If one fan is rated at 50dB @ 27C (81F), how will I determine what the projected noise level of 12 combined fans will be? Is it a cumulative number? Is there a formula to figure this out?
Thanks in advance,
Ron
