Thread: Height of air duct inside warehouse
    Engineer
    Nov 2012
    16
    What should be the approximate height of a supply air duct inside a warehouse whose side walls are 6 meters high and racks for storing goods would be 5 meters high. I am more interested in knowing the height if air diffuser grille from FFL is this warehouse. Thanks
    High enough that your forklifts won't wipe them out...
    Ummmm, you are kidding right?
    If the racks can be filled to 5-meters high and the ceiling is 6-meters, then I would be going for at least 5.5-meteres to the grille center-line. Well, unless you only wanted to cool/heat the stuff on the first row of racks.
    If that was a serious question, then I fear for the future of Engineering design.
