Thread: LMC-Least Material Condition
    Mar 2013
    ipt>
    When should be necessary to use the Least Material Requirement for an external diameter?? What is the application?
    2,580
    Sometimes to control minimum wall thickness for a pipe or similar part..
    Sep 2013
    LMC is used for minimum wall thickness or minimum distance on the part.
