Thread: odd o-ring sealed fitting need help identifing
    swanlzsong
    I have a strange fitting that I have never seen before and have been unable to locate any information on. The fitting has straight threads and terminates in body seal o-ring. The threads are 1mm pitch and 14.6 mm major diameter. Attached is a picture of the offending fitting. Any help would be appreciated!
    Aug 2012
    UK
    433
    I've come across similar fittings used in the Poly-Pipe, push fit plumbing systems. Not an exact fit for your picture but damn close.
    You might send your picture to a few plastic fitting manufacturers to see if they recognize it. Try:
    http://www.colder.com/
    http://www.coleparmer.com/
