Thread: water treatment experiment design
    Jun 2014
    hello
    this is the first time I'm using this forum so I hope that my post is in the right sub-forum
    I'm working now on a project for water treatment , I don't know exactly how to design the setup of the experiment.
    what is needed
    1- 50l feed water tank connected with a pipe , I have to use different water velocity,pipe diameter and flow rate on this pipe.
    2- at the end of the pipe part of the water will be directed toward tank , and the rest will be directed to 2 RO (reverse osmosis ) .
    3- the product water from RO will collected in a tank.
    I need economic and effective setup ,with proper distribution for pumps , valves and if any other equipment is required.
    the attached image is a sketch for the set up.
    regards
    776
    Welcome to the forum, but I think you might be expecting a little much. It appears that you are hoping someone here will design the whole thing for you. More specific questions will get specific replies.
    431
    When ever I see a post like this, where system parts are named but there is no attempt shown for working it out, I always think it's a class assignment. Maybe I'm just being overly suspicious in my old age.
    Jun 2014
    I'm sorry may be there is something wrong in the way I discussed the issue , for the design I try to do sketch only but I'm survey engineer and this the first time I have such a job as emergency case ,I don't have a background in water engineering , and it's not a class assignment, I will try again .
    regards
    Sep 2014
    Well!! I think some experienced architect can advice you well regarding this issue because water treatment design is very much critical according to all aspects.
    Sep 2014
    35
    Engineering and Civil
    This is a great content about the engineering field as here we use various types off content like, Austempering Technology, Austemperetc. As these are helpful in the construction field as well as in various industries.
    Nov 2018
    Abu Dhabi
    28
