Thread: Selection of Steel Round for application in weightlifting equipment
    Nov 2014
    This is my first post here. I am basically looking for a steel for making a barbell. The barbell will be 220 cm long (standard Olympic barbell). I probably cannot post any link yet. So my requirements are that the bar should flex to a certain degree but return to straightness. So it needs to have high tensile strength (~ 190000 psi) and yield strength (~ 170000 psi). Standard alloy steels seem to be too brittle at these strengths. So maybe I need some spring steel. Also the steel will be knurled and machined before final assembly. Can someone help me out please?
    Thanks
    2,327
    170 ksi? A larger diameter barbell would allow the use of much more industry standard materials..
    Nov 2014
    Thanks but I forgot to mention the bar must be 28 & 29mm.
    Sep 2014
    35
    this is a good idea to do the selection of steel round. This is a favourable article about the steel round.
