Thread: Torquing Policy
    Engineer
    Jan 2015
    Pittsburgh, PA
    14
    Torquing Policy
    Anyone have a "Torquing Policy" in their company? I wanted to compose a documented procedure that all technicians must adhere to when building machines. We are fast expanding company and i want to implement more quality assurance procedures.
    Thank you,
    John
    2,612
    From AC 43.13 FAA
    Torque:
    The importance of correct torque application cannot be overemphasized. Under torque can result in unnecessary wear of nuts and bolts, as well as the parts they secure. Over torque can cause failure of a bolt or nut from overstressing the threaded areas. Uneven or additional loads that are applied to the assembly may result in wear or premature failure. The following are a few simple, but important procedures that should be followed to ensure that correct torque is applied. NOTE: Be sure that the torque applied is for the size of the bolt shank not the wrench size.
    a. Calibrate the torque wrench at least once a year, or immediately after it has been abused or dropped, to ensure continued accuracy.
    b. Be sure the bolt and nut threads are clean and dry, unless otherwise specified by the manufacturer.
    c. Run the nut down to near contact with the washer or bearing surface and check the friction drag torque required to turn the nut. Whenever possible, apply the torque to the nut and not the bolt. This will reduce rotation of the bolt in the hole and reduce wear.
    d. Add the friction drag torque to the desired torque. This is referred to as “final torque,” which should register on the indicator or setting for a snap-over type torque wrench.
    e. Apply a smooth even pull when applying torque pressure. If chattering or a jerking motion occurs during final torque, back off the nut and torque.
    NOTE: Many applications of bolts used in aircraft or engines require stretch checks prior to reuse. This requirement is due primarily to bolt stretching caused by over torquing.
    f. When installing a castle nut, start alignment with the cotter pin hole at the minimum recommended torque plus friction drag torque. NOTE: Do not exceed the maximum torque plus the friction drag. If the hole and nut castellation do not align, change washer or nut and try again. Exceeding the maximum recommended torque is not recommended.
    g. When torque is applied to bolt heads or cap screws, apply the recommended torque plus friction drag torque.
    h. If special adapters are used which will change the effective length of the torque wrench, the final torque indication or wrench setting must be adjusted accordingly.
    See:
    Torque Wrench Adapter Extended Equations and Calculator
    Torque Wrench Adapter Reduced Arm Equation and Calculation
    Engineer
    Jan 2015
    Pittsburgh, PA
    14
    Very good stuff. Thank you very much kelly bramble. You are a wealth of knowledge.
    John
