Results 1 to 1 of 1
Thread: Hex planes GD&T
    Happyfeet63
    Hex planes GD&T
    In the attached PDF, the small hex sides need to be parallel and aligned angularly with respect to the large hex to within +- 0.005. The question is does the angular FCF tolerance need to be in degrees? Secondly, are the tolerances and nomenclatures reasonable and, if so, correct and measurable?
    Attached Files Attached Files
