Thread: Help with a project in the university
    Jan 2016
    Angry Help with a project in the university
    Dear readers and colleagues,We are Materials Engineering students at Ben Gurion University in Israel.
    In our studies, we have a project which we need to do in Solid Works.
    We decided to build a stick that helps cleaning high places such as door lintels.
    Our idea is to put a small water container inside the handle of the stick, and with some kind of a straw or pipe to withdraw the water on the other side, where we will add a rag.
    As first year students, we don't have enough knowledge about the materials and the mechanical systems that we can use in order to build that.
    We have two main dilemmas:
    1- What kind of straw should we use that will be elastic, flexible and durable (we want the customer to change the length of the stick as needed)?
    2- Which mechanism should we use in order to withdraw the water from the container to the rag (the handle should be in the lower part of the stick and the water will exit from the top side)?
    Of course we will be more than glad to hear more ideas and possible ways to improve our product. Thank you in advance!
    Jan 2016
    May want to reconsider your design to include some sort of hydraulic action to get the water going against gravity and to control the flow rate. Maybe consider looking at some paint sticks or water pump guns (generally kids toys) to get some ideas and make the rag removable for faster filling.
    Make each extension section modular, "straw" and all. Put a finger-powered squeeze pump in the bottom section.
    Jan 2016
    First of all thank you for your answers.
    We do consider adding some hydraulic action. We'll check the system of water pump gunes and we'll try to figure out how to control the flow rate.
    We also thought about making all the extensions modular, exepct for the straw. We also thought about building some kind of pulley, and wrap the straw on it when the stick will be "closed".
