Thread: What paint finish most closely resembles LDPE?
    Dec 2015
    6
    Hello
    What paint finish most closely resembles smooth LDPE? (Low Density PolyEthylene)
    I have made some prototype using 3D Printing using SLS of Nylon 12 material (Fine Polyamide PA 2200).
    Apparently sintered Nylon sucks up paint surprisingly well. However I need a paint that has the mechanical properties of LDPE. In particular I need a paint finish that is slippery with a similarly low coefficient of friction.
    Any suggestions?
    J
    Dec 2013
    4
    So simple powder-coating won't cut it? I think the material used for powdercoating is some sort of polymer, like polyurethane or polyester. I've also seen things dip-coated in PVC and PE.
    So maybe you can get a part coated with polyethylene via the dip-coating of powder-coating methods.
    Aug 2012
    UK
    425
    PTFE, PFA, FEP? It's going to depend on what you're specifying the coating for. Some of these don't play well at high temperatures.
    Apr 2016
    4
    I suggest you contact paint supplier who know better than an engineer here
