Results 1 to 8 of 8
Thread: Help with Aquarium stand made of Aluminium
    Apr 2016
    Question Help with Aquarium stand made of Aluminium
    Hi all,
    I am new to this forum and I don't have much experience building stuff on my own either. Circumstances have forced me to get into this however, and I have a lot of interest in continuing with a DIY hobby. Now to my question.
    What I am trying to make is an aquarium stand using aluminium square tubes. The tubes are 1.7" by 1.7" with 1/8 of an inch thick walls. The stand will have to hold an aquarium of weight 300kg. The finished stand will look like this in the image below. By the way, the tubes are nothing like that in the design below. Its just normal square tubes.
    The problem is connecting the tubes. I am thinking of using L or T brackets. But How do I fasten the brackets? Do I use bolts or rivets? Here is a picture of what I am talking about...
    Any suggestions?
    432
    I go with bolts (probably coach bolts) and a pretty stiff bracket. that way, at least you can easily disassemble and reassemble if necessary. just bear in mind that if the bracket is too thin you'll end up with a bit of sway as all your joints will effectively become a hinge.
    Apr 2016
    Thanks Cake of Doom. I hadn't given much thought to the bracket strength but you have a good point. Thanks a lot!
    Apr 2016
    Oh and what size bolt would be good?
    432
    Just on gut feeling, probably an 8 mm (0.32"). I'd add a washer to the nut side too, to prevent the section from pinching; just in case it gets over tightened a bit.
    2,218
    777
    m0jc4QdxOcMrWp3Q6LNwaZQ.jpguniversity-fastening-options-img10.pngJoint stiffness is going to be your BIGGEST issue. Once the load is even just a little bit off center due to whatever cause, its coming down. I would not use bent metal brackets at all. I would use triangle shaped plate brackets bolted in two directions at each outside corner top and bottom.
    432
    ^ Those were along the lines I was thinking of, or at the very least, something like these:-
    I suppose that'll come down the finishes. Whether or not it's going to remain open or be covered with some sort of facia.
