Thread: ASME Cone design calculator
    Aug 2016
    Red face ASME Cone design calculator
    The posted calculator does not refer to the 30 degree half-apex angle limitation (as stated in ASME Section VIII UG-32).
    What is the best/easiest way for calculating the strength of a conical bottom if this angle exceeds 30 degrees?
    Thank you & regards,
    Joel
    Newark, NJ
    195
    I think that the standard states that for when the half-apex exceeds 30 deg. a reinforcement ring can be included to stiffener the cone structure.
    Read all the rules in UG-32
    A reinforcing ring shall be provided when required by the rule in 1-5(d) and (e).
    Conical heads or sections having a half apex-angle a greater than 30 deg. without a transition knuckle shall comply with Formula (4) and 1-5(g).
    Aug 2016
    I think that if this is the case then it should be added to the online calculator so that limitations and following steps are clear...
    2,171
    Quote Originally Posted by joel_bogaert View Post
    The Cone Design calculator determines the cone design parameter accurately. A reinforcement ring is required if ASME certification is required and the angle exceeds 30 degrees..
    If you choose to design a cone transition at 31 degrees the cone design data will be determined. You seem to be suggesting that the calculator should inform you to use a reinforcement ring.
    To be clear, the calculator is for determining the geometry, not required welds, weld penetration, engineering materials, surface finish and all of the other design engineering requisites..
