Thread: Real life statics question help
    Oct 2016
    Hello all, it has been a while since I took statics, so I am hoping someone can help me out with this real life problem.
    Let's say that I have a curved, solid, cylindrical piece of steel that is about 2 inches in diameter and about 1 foot long. On one side it is attached to something that can be considered as fixed and on the other side, there is a 400 pound weight.
    If I want to add a v-notch to this piece of steel, so that it fractures as the weight bounces up and down, where would be the best place to add the notch? I was thinking the best place would be at the bottom of the curve where both sides start coming back up, but wasn't sure.
    Here's a rough MS Paint picture and a real picture showing said piece of steel. Thank you.
    Links removed...
    2,613
    Drop box requires an account ... upload images directly to this forum..
    Put the notch on the tension side, where it will be the initiator of a crack. That means it goes on the top.
    Nov 2018
    Abu Dhabi
    28
