Thread: Metric gears
    Oct 2013
    94
    Metric gears
    I have driver and driven shaft at c/c 62.11mm I need a 2:1 ratio. Is this possible?
    Oct 2013
    94
    Quote Originally Posted by GlennD View Post
    I should have asked if this was possible with properly meshed metric gears ... and yes, it is certainly is possible.
    May 2015
    217
    So the pitch radius of the pinion will be 1/3 of 62.11 or 20.703. Hence the pitch diameter of the pinion will be 41.4 and the pitch circumference 130. The other gear is twice as big
