Thread: Common Train Air/Rolling Resistance Values
    Oct 2016
    Hi all,
    I am working on a project relating the spring constant of a spring buffer and velocity of trains of different masses on an incline. I need to find a rate for how the train velocity at the point of contact increases/decreases as the mass values increases (this is the change in velocity over mass over several scenarios--not a time rate for one train in one situation). To find that rate, I've been looking for common values for air resistance or rolling resistance for a train. I'm having trouble finding these through Google--does anyone know of a good,resource for finding this kind of info?
    Thanks!
    Aug 2012
    UK
    425
    Best I can give you is: check your local codes. Your OP is quite sparse with regards to information; is this train freight, engineering or passenger carrying? Does it involve fully loaded, partial loading or empty states? Trains have a maximum incline they can travel without additional assistance so thats something else to check out. There are also track/rail design handbooks out there if you're willing to part with some $$$$.
    Oct 2016
    Thanks for the tips, Cake of Doom. My project is pretty simplistic--I just need some values (it doesn't matter whether they are for freight or passenger to me). Would those codes just be available from the department of transportation, I guess?
    Aug 2012
    UK
    425
    That would be a good first port of call. If they can't supply the information they should be able to point you in the right direction.
    Aug 2012
    UK
    425
    If they can't help, contact the/a carriage manufacturer. They'll have the wind tunnel results for air resistance and probably the rolling resistance values too.
