Thread: Question about Mechanism
    Dec 2016
    I am interested in a Mechanism which i will have to use in a machine i am working on. The motion of the mechanism has to be it halts for 6 seconds then makes a stroke in the liner direction in 3 seconds and then again halts for 6 seconds. The length of the stroke should be 300mm.
    Please help with such mechanism.
    NOTE: It is a 1000mm x 1400mm machine therefore can not use CAMs of larger size.
    Aug 2012
    UK
    433
    Sounds like the sort of interrupter used in presses or production line shear cutters.
    You need to describe the full motion. What you describe is the requirement for only 1/2 of the units stroke, if this is the extension stroke then what are the requirements for the retraction stoke?
