Thread: How can I convert files from RDM6 to Solidworks?
    Dec 2016
    For a research project we have made a model in RDM6-Element Finis. We would like to convert that file to .SLDPRT (Solid Works Part file), because we want to print that model using a 3D printer. Unfortunately I have not found any useful information on the internet on this matter. From RDM6-Element Finis, the projects can be exported (saved) to the following file formats: HPGL, HPGL2, POSTSCRIPT, WMF, EMF. What solutions are there available to convert this file? What would you recommend?
    Thank you in advance!
    243
    Can you first convert to a step file then import into Solid Works?
    Dec 2018
    India
    11
    I give you some step by which you can convert file to Solidworks
    • Click Open (Standard toolbar) or File > Open.
    • In the dialog box, in Files of type, select the desired file format: ...
    • In the dialog box, browse to the desired file.
    • Click Options.
    • In the System Options dialog box, set options including: ...
    • Click OK.
    for more details you can refer solidworks website
