Thread: Datum Target Application on Drawing
    Mar 2017
    I have some experience with geometric tolerances but am not fully confident with the above application using a datum target in combination with note 6. Any assistance or comments would be greatly appreciated. We use a non contact measuring system that can measure in the z direction so we are trying to make sure the drawing exhibits these actions and eliminates any confusion with our supplier.
    2,237
    As a primary datum "A" the three points of contact should not be in a straight line... To create a datum plane one needs a minimum of three contact areas not in a straight line.
    Mar 2017
    I see the error for Datum Target A1. I am thinking if I remove the Datum Target A1 and leave Datum A and than revise the note to say measurement to be taken at dimension .761 basic dimension location instead of from target A1.
    2,237
    Quote Originally Posted by mbarrett View Post
    With the limited information I have on fit, form and function --- sure, that will get you a datum plane..
