Thread: How does pressure change in a pipeline if, it
    Mar 2017
    What happens to the pressure when you have one pipeline with 1 bar pressure that ties to a common head wither another pipeline with 7 bar pressure. Does that 7 bar fluid stop the 1 bar fluid going in?
    2,298
    Depending on the design of the system, check valves or not the 7 Bar source will be the pressure minus pressure loss from flow.
    Apr 2017
    Hong Kong/Florida
    Y-Spring Check Valve, or Swing Check Valve
    810
    Two adjoining pipes with no valve in between cannot have different pressures. The 7 bar pressure will fill the volume all the way back to the valve in your diagram. If it is a check valve holding back the 7 bar pressure, it will only open when the pressure on the other side exceeds 7 bar. There is no way to feed fluid under 1 bar pressure into a volume at 7 bar pressure. I am ignoring pressure losses due to flow.
    May 2017
    It's possible the pipe is obstructed inside. Perhaps rust scale, large glob of pipe dope, etc.. That would impede pressure balance I think. Just a thought.
    Nov 2018
    Abu Dhabi
    28
    To understand the relationship between the pressure drop across a pipeline and the flow rate through that pipeline, we need to go back to one of the most important fundamental laws that governs the flow of fluid in a pipe: the Conservation of Energy, which for incompressible liquids,
