Thread: Load calculation help
    mehtakrunal
    Torque is transmitted by a gear to a shaft with a keyway offset to the center of shaft...Two rollers are attached at the end keyways of shaft..by calculating tangential and radial forces on gear i have calculated the load on central key way but i dont know how to calculate th forces on end keyways..pls help..
    A diagram or picture would help a lot. I read your question several times and do not have a clear understanding. See Forum guidelines on posting images.
    JB, I think this is what he is after. I am not sure if it is Homework or not though.
    Thanks Dave. I thought that might be the case myself, but it took several readings to arrive at that conclusion. Its still a guess though.
    Happy New Year to you!
