Results 1 to 6 of 6
Thread: Pizza Oven base
    Pizza Oven base
    Hello everyone
    I'm looking for a little advise on fabricating a pizza oven base from mild steel and I
    need to know if the tube size and thickness is going to support the weight.
    I was thinking of using 50mm x 50mm x 6mm thickness square mild steel hollow section and the weight of the oven
    will be around 1200kgs. Standard square top with 3 supporting bars and 4 braced legs.
    Any advice would be greatly appreciated.....
    2,067
    A36, carbon steel. Keep it simple.
    see basic design
    2,067
    Looks good to me... Welding?
    May 2015
    109
    If you do not have a fabrication shop handy, you can buy custom tables.
    Take a look at American Grinding:
    http://www.americangrinding.com/brut...s-gallery.html
    Banned
    Nov 2017
    Sounds good. Mild steel should be enough in my opinion or would you be open to other options?
