Results 1 to 1 of 1
Thread: Hydraulic schematic
    Nov 2017
    Hydraulic schematic
    I am trying to draw a schematic for a hydralic system.
    The system will have a pump that provides:
    24cm3 deplacement
    I will also try to pick 2 cylinders (double-acting?) that can lift a hatch (45kN needed for each cylinder).
    I also need to stop the hatch from going down in case of internal leackage from the directional valve.
    the hatch should also have a lock that should be oporated with the hydraulic cylinder.
    The lock only applies activated when the door is closed. (Closed door = locked door)Picture below is what i have come up with so far in my drawing. What am i missing? what should i adjust?Thanks in advance for every inputs!
