Thread: Beam capacity
    Dec 2017
    Beam capacity
    A square tube steel 3.5 x 3.5 x .1875 thk beam would be 120" in length, and cantilevered 60". 60" would be through bolted and adequately supported/integral to a sheer wall. What would be the maximum weight at the cantilevered end without deflection?
    Thanks, bill
    2,091
    Not being silly but zero applied load means no deflection. With the application of any load on any structural beam there will be a deflection - small but it will occur.
    What is the maximum deflection you realistically need?
    You can see equations and access deflection and stress calculators here...
    Jun 2018
    I would like to know the lifting capacity of an I-beam. We have hooks which can carry a load of 1.5 tons each (4nos welded). We have made holes of 6 nos, holes below in the edges of I-beam to anchor and lift a concrete block of 2.8 Tons. We will be lifting off the concrete block by method of chemical anchors. We have 6 nos holes in which we will attach 16mm threaded bolts upto 200mm depth in the concrete block.
    Chemicals and anchors are from Raw plug and they have certified the chemical works.
    I-beam Length being 2 Meters.
    200x200mm x 10mm thick.
    Would like to know if this I-beam can carry a weight of upto 3 tons.
    747
    I don't know. What does your analysis say?
    Newark, NJ
    189
    First, determine the area moment of inertia:
    https://www.engineersedge.com/materi...pes_viewer.htm
    Then, determine the loading configuration:
    Input the loading/force, etc. and solve for your design.
    Quote Originally Posted by roshan_shenoy View Post
