Thread: Concentricity on the thread
    Dec 2017
    4
    can someone help me solve onging discussion wihin Engineering dept. I enclosed the example of Concentricity marked on the thread realted to two smaller diameters located before the thread itself.
    I've been trying to find a standard which expressly explains if its according to GD&T rules.
    1) Is this annotations by the thread correct to the GD&T rules ?
    2)It is possible to measure the minor diameter of the thread and its position to other holes to establish the concentricity, but is it possible somehow to measure the thread concentricity ot it would be enough med minor diameter of the thread ?
    Explanations will be more than appreciated as basically there is a war going on !
    2,170
    If the drawing is to the ISO 1101 standard - the Concentricity is interpreted like Position tolerance.
    If the drawing is to the ASME/ANSI standards - it would be an incorrect application. ASME/ANSI Concentricity tolerance is the condition where the median points of all opposed points or surface elements of a feature of size are contained within a circular tolerance boundary defined about the specified datum axis. Which a thread feature cannot be measure to.
    May 2015
    140
    You could make a gauge that centers in the 18 mm hole that could measure thread runout.
    I'm not sure how you check the finish on the 15 mm back bore.
