Results 1 to 7 of 7
Thread: Avrami equation help
    Feb 2018
    4
    Good evening
    I am after some help. I have a set of tensile results that I need to produce a graph using the avrami equation. Would somebody be able to give me some tips of where to start. I cant figure out how the results would fit into the equation
    kind regards
    James
    Aug 2012
    UK
    420
    The JMAK gives you the fraction of transformation and a time interval so, I suppose, an x-y type of graph could be the simplest form.
    Feb 2018
    4
    Thanks for you reply, I am just unsure how to go about this, I obviously have time / load / extension for the tensile test.
    How does this fit into the avrami equation y=1-e^kt(^n)? I 'm guessin t=time, y=extension, if that's right how do I find K & n?
    thanks
    James
    2,138
    If you have test data just create a x and y column then a line graph in excel. The Avrami Equation will normalize the selected data given not report exact data.
    Feb 2018
    4
    so the x / y graph would be stress strain as per normal way to show tensile results? As the avrami is fraction of transformation vs growth (nucleation). How do I change a graph to show this if that's the case?
    regards
    James
    2,138
    You need a sufficient number of x y data for the stress train curve.. That's all - extrapolation should be OK for gap in the data.
    Feb 2018
    4
    is this not what a avrami curve is? if so how do you convert stress/strain to this? Unless I've got it completely wrong.
    regards
    James
