Results 1 to 10 of 10
Thread: Help with C02 Canister Regulation
    Apr 2018
    5
    I am building a simple pneumatic system which is powered by disposable 16g CO2 canisters. I'm continuously blowing either tubing or my ptc fittings, all of which are 1/8"npt->1/4" tube from Pneumadyne.
    From what I have read, when you puncture one of these things it unloads at >800psi.
    Would you recommend I beef up my tubing/fittings? If so, please provide links.
    Or, should I figure out how to regulate the flow coming directly out of the canister? Again, please provide links.
    I have tried 3 different pierce CO2 adapters/"regulators", but even with a tiny turn of the valve I am getting blowouts.
    Thanks for any input!
    2,314
    What peak pressure is the system operating at?
    Apr 2018
    5
    From what I gather, the CO2 cartridges put out around 850psi when they're first punctured.
    OK, but what is your desired/required operating pressure for your system operation?
    Apr 2018
    5
    Hard to say what is optimal since I haven't tested the new design, but the system tops out at 200psi. I'm running a standard compact cylinder off 16g CO2 canisters, using a standard 3-way switch from Pneumadyne. My guess is that I want to be in the 100-150 psi range.
    Here is the regulator I am considering buying... just wish there was a cheaper/simpler option.
    https://www.*********a/Regulator-Char...HY06P8FYB1444X
    Cheers,
    2,314
    Whatever verified peak pressure that your system operates at you should select and design all system components to operate at a pressure not less than 1.5 x greater. The factor of safety is to protect you and other operators as well as ensure system dependability.
    Apr 2018
    5
    Thanks for that, makes sense. However, this is just a personal project, and I know there are many other products out there that use CO2 canisters and don't operate at 500psi.
    If you have suggestions for a different portable/reusable gas supply I would like to hear it, or if you can think of a better regulator option.
    There is very little gas volume in these small cylinders (approx 120 cu in at 150 psi). Are your sure that will be sufficient to operate your system for the operating time you want/need?
    Apr 2018
    5
    Yes, I'm sure, thanks.
    Really just here for potential alternatives to this regulator:
    https://www.*********a/Regulator-Cha...HY06P8FYB1444X
    Cheaper or smaller, or both.
    Cheers,
    Quote Originally Posted by dangerabercrombie View Post
    Cheers,
    Amazon links and other marketing links not allowed.... Find the specifications and post here.
