Thread: compatibility question
    May 2011
    9
    Im installing a galvalume metal panel roof. Supplied steel screws are used to hold the panel clips to the roof wood deck. Some of the wood is rotten and/or termite damaged. So, we have been replacing that with treated wood. I just heard that galvalume is NOT compatible with treated wood. Several sites did say that the peel and stick underlayment is sufficient barrier. However, that leaves the screws. Steel screws are NOT compatible with treated wood.
    Some sites say hot dipped galvanised is compatible with treated wood, however hot dipped is still zinc and zinc is NOT compatible with treated wood.
    What can i do, other then replace the treated wood?
    paul
    May 2011
    9
    I forgot to say. SS is NOT compatible with galvalume.
    2,418
    I just went to the galvalume folks website. I don't think they could be more vague or devoid of useful information. They do have a contact form on the website but they really need to provide some specifications.
    I know that for most metal roofs there is a rubber-ish washer between the screws/nails and the metal roof sheets. I suppose one can buy these at most consumer hardware stores. The rubber washers do eventually fail (20 years?).
    I have no idea on what the relative construction of the galvalume sheets are.. Aluminum over zinc or zinc over aluminum or some alloy of the two. If you can determine the composition they you might know the best approach to secure the sheets to the wood structure.
    202
    The best reference that I know of for metal rooks is the Fabral Blue Book:
    May 2011
    9
    i pulled the treated wood. just too risky.
    434
    It sounds like Galvalume has probably been designed for use with Metsec or other proprietary type purlin systems. Sorry you had to rip out your new roof.
