Thread: Shraeder/Presta Cycle Tire Standards
    May 2018
    6
    Hi
    I need details of presta and shraeder valves - for a hobbyist design project (cycle tire inflater).
    Internet searches only provide most basic info - not enough to design a connector from the inflater to valve around.
    I have obtained an old copy of The Tire and Rim Association Year Book but it does not give the required details.
    I am considering obtaining ISO/BS standards but I'm not sure that they would have the info that I require.
    Can anyone help me with where to look/who to contact for such details.
    Thanks in advance.
    Rich
    236
    Buy a Schrader valve - reverse engineer it.. Or, buy a Schrader valve adapter and reverse engineer it.
    From your description I am not sure exactly what you are looking for, but the attached Schrader document gives the dimensions for a valve stem internal socket and thread to receive a Schrader valve.
    Valve Core Brochure.pdf
    May 2018
    6
    Thanks for your replies and thanks for the brochure.
    I'm not sure that it contains a cycle Presta Valve.
    I have access to BSI/ISO standards at work and think I have found the documents I need but certainly in the second document below none of the valves are stated as being a Presta cycle tire valve.
    ISO*4570:2002(en)Tyre valve threads
    ISO*9413:2012(en)Tyre valves* Dimensions and designation.
    I'm finding that in engineering finding pertinent information on standard parts can be quite a challenge.
    Cheers
    Rich
    Mar 2018
    threads.pdf
    Presta valves are 5V2, check here , may be that's what you need
    Nov 2018
    Abu Dhabi
    28
    but the attached Schrader document gives the dimensions for a valve stem internal socket.
